Component Identification help
dark
Hi Board,
Could you guess the component marked "?" in below Image.
This piezo driver side of 40 Khz Transducer. The number is unfortunately missing .
Regards
It may be a resistor array. Can you post a bigger image?
Its an IC package Like this **broken link removed** from some piezo driver domain .
VCRs used to have a h-bridge small DC motor driver IC in that SIL package, which would be possible to use as a transducer driver. I have also seen small mono amp ICs in SIL packages too, which could also be used as a transducer driver.
But the PCB as shown above is also using transformer to step-up, therefore is there a possiblity of using a mono amp IC or h-bridge driver ? . i am not sure.
Absolutely. Both the mono amp or DC motor driver would expect a low ohms load. The transformer would convert that to a higher voltage lower current suitable for a piezo transducer.
Why did you need to ID the chip? Is the device faulty and needing a chip replacement?
True , The chip is working I am studying what is going on . I am sorry but I couldnt search h-bridge driver / mono amp in the above stated package , most of the packages has sinks so I am still guessing what could it be.
A quick google for "8pin SIL amplifier" found a few on the first couple of pages;
NJM4556AL opamp
M5218L opamp
LA3161 Stereo Preamplifier
NJM072BL, OPERATIONAL AMP 8PIN SIL
(there are more 8pin ones there if you look). :)
I think the DC motor drivers or power amps might have more pins, I spotted this one;
ILA2616 IK-Semi SIL-9P 2x12W stereo power amplifier TDA2616
NJM4556AL opamp
M5218L opamp
Thanks, so it looks like these are opamps in push pull mode .
