Hank Fletcher
I was doing some repair work in the ceiling above a small room in my basement this weekend. There was quite a problem with a leaky dryer vent (the room is right under the mainfloor laundry room), but that's all sorted out now. The only moisture coming into the room now is some small drips coming off the cold water pipe (copper) feeding the washing machine. The leaking (if it's that) is coming from about a foot-long section, and I'm guessing if it's a leak it's at the joint at one end, which by necessity is at a bit of a funny angle.
It's hard to tell for sure exactly what's going on because the pipe is wrapped in white foam insulation, taped on with copious amounts of duct tape. The fact that there's still moisture there is leading me to believe it's a small leak, and not condensation. The other copper pipes (including cold) are dry - is it possible that this bit is coldest because of the amount of cold water flowing through it? That seems like wishful thinking, because I'm not looking forward to soldering the pipe.
So that's where I'm at. How can I know for sure it's a leak, and if it is, is soldering a new section of pipe in my only option? I was just wondering if anyone knew of any other solution (some kind of adhesive that can withstand the high pressure in the pipe?), because I'm not confident at all in my abilities to solder copper pipe, especially with all the wood frame around! I should probably mention that it's a very small amount of water, on the order of one cubic centimeter every half hour or so. Not bad enough to call a plumber, but serious enough to damage the ceiling tile and to cause concern for the future.
