TheBabaBoss7
Hello, I wanted to ask, if there is Sensor that is faster than the CNY70, and that looks similar. I need it for a mall circuit.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I think it will be hard to find a object flying faster than the CNY70 can see.if there is Sensor that is faster than the CNY70
The sensor is a reflective photo sensor typically used to photo sense objects at about 6 mm. It is not designed for use in distance measurement. It uses an open collector output so it is designed to sense objects within its range use providing a yes/no output as to the presence of an object in front of it. Like abjects moving past on a conveyor.i need to build a Digital distance measurement, and i have 3 CNY70. I wanted to know if there is maybe a better Sensor, just to "upgrade" the circuit. It is not very important, i can work with the CNY70 sensors without any problems.
