Thread starter
#1
Mainly for Western who is attempting to build a oil fired boiler that runs on non veg (i dont thin he is using veg oil) oil. Specifically this is more for normal type oil boilers that are converted to run waste 'oils'.
For most people these are likely to be normal car/van engine type oils. For some people (mainly those in agricultural areas) the waste oil is likely to a untold mix of different fluids. There is a video posted somewhere with a method of using a centrifuge type system as a stage in cleaning up the oil, i will try and find a better one to post.
There are many ways why its best to clean the oil, in all cases check the regulations for where you live, even within the UK there are different rules according to the area type you live in. So check emission rules! All OIL fired boilers in the UK have strict legal limits for emissions, many of these are actually based on safety such as the amount of Carbon Monoxide you are allowed to produce.
From memory Aus has very similar rules, so keep in mind when i post the list later, it may or may not apply to where YOU live, do not skimp on the yearly test, it is not that expensive to have your boiler checked once a year, in many places it is also a requirement to do so. In the UK non compliance with these rules will cost you MANY times the cost of getting a pro in and getting the test done.
Without adding drama keep in mind if you dont have that bit of paper, and someone dies from say carbon monoxide poisoning, then legally you could be facing a very lengthy prison sentence.
The good news is.............Most of the time, cleaning up oil to burn isnt that difficult and tuning your system to burn the oil efficiently shouldnt be too hard.
I will post a video on the centrifuge system, this should be seen as a part of cleaning and not the only method used. Then we can go into other methods etc.
The House boiler we have now does not use waste motor oil, it was installed very recently so i havnt converted this one yet, the one that runs part of my workshop etc is converted. I tend to find it easier to get Fat from fatbergs in sewers than waste motor oils, so much of the time we run our boiler on home made bio diesel heating oil. This is slightly different to the biodiesel fuel we make for the tractor and car.
If Western is interested i can go into turning solid fat from sewers into heating oil. Oddly enough fatbergs in sewers are actually a hard for of soap and not fat as such, so they need processing first. But the oil you get from the processed waste is as good as purchased heating oil (IMHO).
