Signalglow
Citroen C4 l 2004 front left ABS wheel speed sensor fault.
Hi, ABS and ESP lights up on the dashboard.
Im getting a reading on Kph when driving on three sensors, except for the front left one.
The left front wheel speed sensor has been replaced plus the ESP module and pump, and the brake-light switch (7800)
(See schematic)
Left front wheel sensor umplugged and connector to ESP module (7800) unplugged.
Measured ohm
7002U to 7001U = IO
7002U to connector (7800) = 0.0 ohm
7001U to connector (7800) = 0.0 ohm
7002U - 7001U to GND = IO
7002U - 7001U to 70012U - 7011U - 7022U - 7021U - 7032U - 7031U = IO
MC702 to GND 0.0 ohm
ME702 to GND 0.0 ohm
Left/right front wheel sensors umplugged and connector to ESP module (7800) plugged in - car is running.
Measured VDC
7002U to GND = 14 VDC - problem here?
7012U to GND = 0.2 VDC
Cant seem to figure this out.
Help is much appreciated.
Best regards.
(See schematic)
Measured ohm
7002U to 7001U = IO
Measured VDC
Best regards.
