circuits parallel and series
mkoike
First question - in a closed circuit does the voltage change across resistors? for example. If you start with 20 volts what is the voltage across the resistor/
Second question - does current change across resistors? If you have a closed circuit with one resistor (R1) then two resistors in parallel (R2, R3), is the current passing through R3 just I = V/R3 or I= V/Rtotal?
Thank you very much!
1) In resistor parallel circuits , voltage doesn't change; In resistor series circuits VRx = Vt * Rx / Rtotal
2) In resistor parallel circuits current across a resistor doesn't change; In resistor series circuits Itotal = Vtotal/Rtotal
Your questions are rather vague.
In the title you wrote "circuits in paralle and series" but there is no mention of "series" in the questions.
I suggest that you post a circuit so we can see what you are trying to do.
A picture is worth a 1000 words.
