Circuit board to control a frequency converter determined by a TORQUE SENSOR
hello again i have done a little research about torque measurements and com up with this:
torque sensor if you the link don't work
or maybe a cheaper edition, i believe that it is necessary with a maximum of 200 nm in measurements just to be safe.
and again i have a problem, little experience with pls or computer controlled stuff.
can anyone maybe come up with a circuit board witch i can select the newton meters that i want the motor to apply to the chains?? if its more easy ti can just be a pot to control the torque. and if i want to read the torque i can use this: **broken link removed**
Transducer Techniques Model: DPM-3 TEDS IEEE Load Cell or Torque Sensor <W if the link dont work
do this have lo alarm and high alarm?
here is the user-manual on the inverter:
it is a Mitsubishi S500
it can be controlled from
a potentiometer 1/2W1k
or current input 4 to 20mADC
the way i want it work is to little nm applied to the shaft increase speed and too much nm applied to the shaft decrease the speed
LINKS ARE FIXED
your links are not working, can you repost them?
