Charger / power pack
spike47
Hi
I buy Broken Laptops and Repair them ( not all ! ) as a hobby , the question I have at the moment is that I have a Laptop repaired and ready to fire up , but I do not have the correct charger / power supply for it .
It requires a 19V 4.5A supply , now I have a couple of chargers but they have a 19.5V 4.5A output , would that extra 0.5 V make such a difference as to blow the Laptop ! .
thanks
spike
No guarantees of course but I'd try it. Nice Avatar by the way.
Hi Sceadwian
Thanks for your reply , I am very tempted to use the other power pack's but I still need a bit more info as to whether it will be ok , I am more or less 100% sure it will be , the reason I am dithering is that I checked the Voltage of the spare power packs I have and they showed one at 19.8V and the other at 19.9V , so I am talking about nearly a 1V difference now , yes I know I should just go and buy a new one for a couple of our £s , but I like to push and try things out its just me .
cheers
spike
You can put a power diode in seiese with it and drop .7 volts.
Hi 4pyros
Thanks for your reply , could you suggest a Power Diode that will do the job ! .
cheers
spike
Any rectifier diode rated for 5 or more amps will work just fine.
