HyperText
I'm trying to change the input voltage of a Xilinx Spartan-3E FPGA (the default one is 1.2V). The board is a Digilent Nexys 2, and of course a tension regulator is involved, hence I have to consider it.
The schematic is the following:
SW1 is the output of the tension regulator and its value is of 0.8V. VCC1V2 is set using the formula: VCC1V2 = 0.8V * [(R78+R79)/R79].
So, by changing the R78 value I can change the input voltage of the FPGA.
However, a user in the Xilinx Forum suggested another solution (https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/Nexys-2-board-variable-supply-to-core/m-p/116380/highlight/true#M3707) consisting of: "Lift one side or the other of L2. You can connect a variable output bench supply directly to the VCC1V2 net.".
Since I'm not an Electronic, I would like some additional informations:
Thanks for any hint,
Pierpaolo
- I just lift one side of L2 and connect a different power supply (let's say 0.9V, coming from a dedicated external power supply), without any particular precaution?
- how should I calculate the VCC1V2 value? Using the above 0.9V value, VCC1V2 will still follow the above equation? So, VCC1V2 would be equal to: 0.9V * [(R78+R79)/R79]?
Pierpaolo
