CCS Compiler - Delay
Key
Im doing my PIC programming using the CCS Compiler. However, when come to delay, i know how to write a simple program that my output delay for a few second.
I was thinking that my output will always high until the user press a button then only my output will become low.
My question is: do i need to do a loop for my delay so that when user press the button then the delay is equal to zero. or is there anything that i can do to my hardware?
3v0
Coop Build Coordinator
Forum Supporter
I read your post a few times and am still confused by it.
First tell us what are you trying to do ?
Then post the code you have so far using the # icon, it will put
tags around the code which will keep the formating and make it easier to read.
Key
Previously i set my output that was connected to a LED for 60second.
That means in my program code i write
delay_ms(6000);
Now I want to let my output to be convenient for user. which the LED switch ON until user press a button and then the LED will switch OFF. So how to do for this?
Mike - K8LH
Then it seems you don't really need a delay routine at all. Simply use a loop that tests the push button switch and lights or extinguishes the LED accordingly. Yes, no?
Mike
Key
Mike
How??? I mean how to loop the push button? i really have no idea of it and im new in electronic and PIC... Plz do teach me... TQ
Mike - K8LH
Well it depends on how you want the push button to act. If you want it to emulate a toggle switch where you push it to switch the light from on-to-off or from off-to-on then you need a simple latch or memory. Here's an example which acts on a "new press" and ignores the "release" part of the switch cycle;
while(1)
  sample = switchpin;    // sample active high switch
  if(sample ^ latch)     // if change (press or release)
    latch = sample;      // update the switch state latch
    if(sample & latch)   // if a "new press"
      ledpin = ~ledpin;  // toggle the LED
If you're using an active low push button switch then you'll need to change the first line in the program;
while(1)
  sample = ~switchpin;   // sample active low switch
New Articles From Engineer's Garage
