lloydi12345 Member Nov 15, 2010 #1 I have designed a PIC and there are left spaces to drill capacitors beside 7805. One is on the input and ground and the second is output and ground. What are the best value of capacitors to maintain the 5v on the PCB?
Nigel Goodwin Super Moderator Most Helpful Member Nov 15, 2010 #2 Read the datasheet - but it's not that critical, I always use small electrolytics because of their small footprint - 1uF to 10uF.
lloydi12345 Member Nov 15, 2010 #3 Nigel Goodwin said: Read the datasheet - but it's not that critical, I always use small electrolytics because of their small footprint - 1uF to 10uF. Click to expand... Nigel what do you mean by small footprint? Can you direct me on what page of the datasheet states the capacitors to be placed?
Nigel Goodwin Super Moderator Most Helpful Member Nov 15, 2010 #4 lloydi12345 said: Nigel what do you mean by small footprint? Can you direct me on what page of the datasheet states the capacitors to be placed? Click to expand... Take up little room - I've never read the datasheet, so couldn't tell you what page it might be on. But it's essential to fit capacitors or it will oscillate, and quite possibly only under certain conditions. 0.1uF is fine, but I find small electrolytics easier.
lloydi12345 Member Nov 15, 2010 #6 Sorry, I thought Nigel was referring to the datasheet of PIC16F877A, Now I found it. Thank you.
J Jon Chandler Banned Nov 15, 2010 #7 You also need bypass caps across the PIC power pins IN ADDITION TO the caps around the voltage regulator. Last edited by a moderator: Feb 14, 2011
lloydi12345 Member Nov 15, 2010 #8 Jon Chandler said: You also need bypass caps across the PIC power pins IN ADDITION TO the caps around the voltage regulator. Click to expand... Yeah I never forget to place capacitors beside the PIC, thanks for the reminder though Last edited by a moderator: Feb 14, 2011
