Capacitor Issue
Hi
I've been working on my project for a while now and have got the infra red link to work.. thanks to help from people on here....
My new problem is with two capacitors.
If you have a look at this datasheet:
https://www.electro-tech-online.com/custompdfs/2004/04/LS7225_26.pdf
the last circuit. There is a 4.7uF (electrolytic?) capacitor that when a key is pressed should charge up and hold the voltage high for a period of time untill it discharges at pin 11, so while it is high the rest of the unlocking code can be inputed. The problem is as soon as i release the key the voltage goes low - i think the capacitor isn't charging or im not using the correct one?? im using a 4.7uF electrolytic capacitor at 63V the circuit is running from a 5 volt supply.
The other capacitor im unsure about is the one between the supply and gnd.. the datasheet doesn't show any values, what kind of capacitor should i be using if one is essential here.
Any help here would be much appreciated thanks
Carl
The capacitor sounds fine, how do you know the capacitor isn't charging up? - your meter could be discharging the capacitor, particularly if it's an analogue one.
The other thing is the 'anti tamper' circuit, this is designed to quickly discharge the capacitor - is that working correctly? - you could remove the transistor to prove is that's the problem.
You should really include one in any circuit, it provides a low impedance path between HT and ground - which is usually essential.
A 100uF should be fine!.
It was a presumption that the capacitor wasn't charging up, as i set the circuit up and tested it but it wouldn't work... so i then put pin 11 to +5 volts to keep it high and typed in the rest of the unlock code and it unlocked but then would have to phsicaly move the wire from +5 to ground to get correct operation...
Yes it is a analogue meter but i would have thought it would have registered a positive voltage for a brief second, no?
Yeah thanks for that does the 100uF cap need to be of any particual type though?
Carl
Try it on a higher voltage range - analogue meters are usually 20,000 ohms per volt - so on a 10V range it's 200,000 ohms, or on 100V it's 2,000,000 ohms. So a higher range will load it less, and also the needle hasn't got as far to travel (which takes time).
Just an electrolytic - anything will do, as long as it's voltage rating is higher than the supply you're using - use a bigger cap if you have one handy, 220uF, 470uF - whatever is to hand.
yeah you were right the capacitor was discharging! I don't have the ls7225 connected to a keypad but an eprom, when you said the capacitor was discharging i thought maybe the eprom output pin is sinking the current!? so i put in a diode and that seems to have sorted the problem out along with a larger value capacitor about 22uF so it would stay charged longer.. Thanks for the help!
Although there deffinately is a problem with the tamper circuit as it should stop you inputing the unlock code for about 12 seconds if there has been a few attemps at entering the wrong code but this does not happen will need to check my wiring on the bread board first i think.
Carl
