Capacitor Higher Voltage Limit?
Tim2
Hey there, I'm trying to find a replacement capacitor for a guitar stomp-box. It's a
DOD - Performer - Compressor Limiter 525, circa 1980. The cap which probably needs replaced
is 0.47uF 16V. All I find is 0.47uF 50V with the same physical dimensions. I understand that
it's acceptable to use a higher voltage, but is there a percentage limit. I bought a bag of
caps at Radio Shack's closeout sell that has a 50V cap in it, but I'm wondering:
1) if 50V is acceptable, and
2) if so, should I buy one from Digi-Key that's rated for Audio use. The Radio
Shack is probably "General Purpose".
Thanks to all of you guys for sharing your experience.
Thanks Ron.
The one from Radio Shack? I was concerned about the bargain cap because the old cap is in line with the compressor.
While your at it replace all electrolytics from Digikey, with solid electrolyte. pref.
Thanks Tony.
I planned on replacing all of those after I was more sure about the voltage ratings. This is a great "vintage" stomp-box. I hate
to degenerate it with low grade caps. Just wanted to get those couple of questions sorted out before proceeding.
I fixed one like that in the mid 70's for a Pro musician friend. It had all the part numbers sanded off on epoxy chips. I fixed it anyways. It had everything from flanger, wahwah, and a dozen others for electric bass.
Those are great old units, carrying a premium price now-a-days; upwards of $200. on eBay & $30.00 for a broken one.
50V is no guarantee of a good quality cap.
It needs to be a reputable source, low ESR and 50% over regulated supply voltage ( 25% min)
Unlikely much power is consumed so high temp of 105'C is an option but not critical.
Probably 12~15V supply.
My suggestion is only use Polymer Caps unless in the unlikely case there is a DC boost or negative regulator onboard with coil that stipulates a certain range of ESR for stability reasons. If so state PN.
https://www.digikey.com/product-search/en?FV=fff40002,fff80532,340043,340045,34004f,340051,34005b,34005d,340066,340068,340080,340082,340089,34008b,34009f,3400a1,3400aa,3400ba,3400c8,3400d6,3400e7,fc016f,fc0173,fc0177,fc01e9,fc01ea,fc01ee&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&pbfree=0&rohs=0&quantity=1&ptm=0&fid=0&pageSize=500
Thanks, Tony. I'll check those Polymer Caps out. I need to replace all of the power caps on an EMU 1820m audio/PC interface, with high quality Panasonic Caps (already purchased them). The original low grade Caps in that unit are causing low quality audio and crackles in the stream. This has made me a little gun-shy about Cap quality.
BTW, the power supply on the DOD stomp box is 18 volt.
ok then 25V min is adequate.
