Hello.
I'm in France , I try untill 2016 to build a Welder with discharge of capacitor , the target ,to solder 2 sheets of aluminium ( 2x2 mm)
I have used 20 xIXYS 100A/100V in // , I used 0.2F under 100Volts ( 900 Joules)
So aluminium have a very low résistance if comparated to iron ( X4 lower) .
I have soon burned 10 MOSFET ..upper than 80 Volts power supply...
I try last week with 32 X IRFP4468 ...in // without success.(32x195= 6240 A pic , Under 1 ms of , "on" conduction ).
That work from 20 to 80 Volts without problem with 20 IXYS ...but without soldering , ...and from 5 to 20 Volts with IRF but without soldering too.
So I remake my calculations , 2 sheets of 2x2 mm of aluminium have a résistor of "800µOhms" Under pin copper of 2 mm diameter Under contact .
So Under 100Volts pic is 100/0.0008 Ohm = 125 000 Ampères pic for 6240 A possible with 32 MOSfet.
For having 1 k.Joule ( energy for solder 2 sheets of aluminium 2x2mm) , I want to uncrease my capacitors to 1000.Farads with 2.7 Volts super capacitors , and I want to put,... 50x MOSFET IRF3711 in //.(50x110=5500 Ampères pic max ).
Curent Under 2.7 Volts for solder to sheets 2x2 mm aluminium Under contact surface = 2.7/0.008 =2750 A making 55 A by MOSFET .
This calculation and this "third project" seam to be good in the real live .
Oh my Mosfet are équilibrating with a 1 milli Ohms (DIY resistor) serial with "source" of each MOSFET.
Is somebody follow my brain storming ...
Is somebody have tried this sort of experience ?...
Jac
PS.
If you add the rDS"on" ...5mOhms (by MOSFET's r DS"on" /32=0.156 milli Ohms)... +3 milli Ohms of "ESR" capacitor 0.2 F , we have till 100/0.003956=25 278 Ampères pic , and only 0.8/3.156 = 25.3% of the energy for the soldering ...intensity too huge and soldering impossible .
Jac
PS.
