Cant get timer0 to interrupt
2camjohn
I have been trying to get timer0 to work on my pic16f628. I have read the datasheets and various websites on the subject. I think I must be overlooking something that is very simple.
Here is what I have done:
At the start of the program:
OPTION_REG.PS0 = 1
OPTION_REG.PS1 = 1
OPTION_REG.PS2 = 0
(Option reg bits 0 - 2 = 110 - sets prescalar to 4th option)
INTCON.INTE = 1
INTCON.T0IE = 1
(intcon bits INTE and T0IE to 1 - enable RB0 and timer0 interrupts)
INTCON.GIE = 1
(enable interrupts - all)
during the interrupt sequence I have
If INTCON.INTF = 1 Then
(if interrupt is generated by RB0)
*some code here, dependant on timer*
else
(else it must have been the timer)
*timer code here*
end if
INTCON.INTF = 0
INTCON.T0IF = 0
(enable timer and RB0 interrupts)
resume
The config i am using is:
IntRC osscilator
Power up timer Enabled
Watchdog timer Disabled
The problem is the RB0 interrupt code works, but the timer0 code never activates. Can anyone tell from my pseudocode what I have missed?
Ive been tearing my hair out trying to work it out.
Thanks in advance for your time
John
OPTION_REG.PS0 = 1
OPTION_REG.PS1 = 1
OPTION_REG.PS2 = 0
INTCON.INTE = 1
INTCON.T0IE = 1
INTCON.GIE = 1
You should also configure bits T0SE, TOCS and PSA of the OPTION_REG.
They configure what signal to use to feed Timer0. Look for it in the datasheet.
else
*timer code here*
end if
INTCON.INTF = 0
INTCON.T0IF = 0
resume
I don't see anything about context saving during your interrupt routine. Look for it in the datasheet.
Try:
OPTION_REG.T0CS = 0
to select the source clock to the internal instruction cycle clock unless you have a clock source at T0CLKI.
Also:
OPTION_REG.PSA = 0
to assign the prescaler to TMR0 if that is your intention.
Here's some tmr0 code I was playing with the other week, perhaps it might help?.
;tmr0 test - Nigel Goodwin 2004
	LIST	p=16F628		;tell assembler what chip we are using
	include "P16F628.inc"		;include the defaults for the chip
	__config 0x3D18			;sets the configuration settings (oscillator type etc.)
	cblock 	0x20 			;start of general purpose registers
		count1 			;used in delay routine
		counta 			;used in delay routine
		countb 			;used in delay routine
	endc
	org	0x0000			;org sets the origin, 0x0000 for the 16F628,
					;this is where the program starts running
	movlw	0x07
	movwf	CMCON			;turn comparators off (make it like a 16F84)
   	bsf 	STATUS,		RP0	;select bank 1
   	movlw 	b'00000000'		;set PortB all outputs
   	movwf 	TRISB
	movwf	TRISA			;set PortA all outputs
	bcf	STATUS,		RP0	;select bank 0
	call	Initialise
Loop
	movlw	0xff
	movwf	PORTA			;set all bits on
	movwf	PORTB
	nop				;the nop's make up the time taken by the goto
	nop				;giving a square wave output
	movlw	d'115'
	call	Delay16			;this waits for a while!
	movlw	0x00
	movwf	PORTA
	movwf	PORTB			;set all bits off
	movlw	d'115'
	call	Delay16
	goto	Loop			;go back and do it again
Initialise
	bsf     STATUS,RP0      ;select page 1
	movlw   B'00000010'     ;fosc/256 --> TMR0
	movwf   OPTION_REG       ;       /
	bcf     STATUS,RP0      ;select page 0
	clrf    TMR0
	bcf     INTCON,T0IF     ;clear flag
	bcf     INTCON,T0IE     ;enable mask
	return
;delay16 waits for approx 16.4mSecs using TMR0 interrupts
;fosc speed is 4Mhz.
Delay16
	movwf    TMR0		;set tmr0 from W
CheckAgain
	btfss   INTCON,T0IF     ;timer overflowed?
	goto    CheckAgain      ;no check again
	return
	end
2camjohn said:
PS what is context saving?
Your interrupt routine needs to save any registers it changes, then restore them before exiting the interrupt routine. In particular W and STATUS are two very important ones, here's an example from one of my tutorials:
	ORG	0x0004
INT
		movwf	w_temp		; Save W register
		swapf	STATUS,W	; Swap status to be saved into W
		movwf	s_temp		; Save STATUS register
		movfw	PCLATH
		movwf	p_temp		; Save PCLATH
		movfw	p_temp
		movwf	PCLATH		; Restore PCLATH
		swapf	s_temp,W
		movwf	STATUS		; Restore STATUS register - restores bank
		swapf	w_temp,F
		swapf	w_temp,W	; Restore W register
		retfie
