Niels Popping
I'm trying to build an frequency regulator. it has an 230V input voltage at 50HZ, that needs to be converted up to 1KHZ.
First I make an DC 230V with some rectifiers. than an 555 circuit on an external 9v adapter is used to create pulses that switches an SSR.
with some resistors that can be selected , I can create pulses between 50HZ up to 1KHZ. the output will be pulsed.
In simulation this works perfectly. but in practice the 555 has an output above the kHz range when the resistors is set up just for 50HZ.
I used this circuit http://www.ohmslawcalculator.com/555_astable.php
with R1 as 1K , (tried different values )
R2 is between 14K and 300K. C1 47NF.
when I put an speaker at the output an high tone noise is produced , not the low frequency I want to switch the SSR.
I don't know what to do anymore, I just need an controlled frequency
