Can JDM program 12F629? Do I need an adapter?
eirikr
Hi all,
I was searching for info on programming 12F629 with the JDM programmer, but all web pages that I found are in Japanese... Does anyone know how to do that?
Any help will be appreciated!
well...knowing JDM programmers, your hardware should output :
:MCLR/VPP -vpp via pullup
:5v -vdd
:Ground -vss
:Data -gp0
:Clock -gp1
These suit the the 12f series. Note:VPP has a pullup resitor.
I'm getting this out of a magazine, so i'm confident that this is reliable. The pinouts should be available on the datasheet.
Hi Pike,
Thanks for the info. Does that mean I can just plug the 12F629 into the same pins that said 12C50x on the JDM schematic? (**broken link removed**) Or do I need ICSP adapter?
eirikr said:
Hi Pike,
The 12C50x use the same pins as the 12F629, so it should be fine (and is on my P16PRO40).
Can i ask you what programmer you are using ??? I mean the software programmer.??
My cheapo homemade programmer just doesn't work with the 'F629 of 'F675. :(
the 12F seires are more fussy than the others about the value of Vpp, teh data sheet says 12v instead of 13v, i've found this to be a problem in the past.
