I recognised this circuit designed by Harry Lythall. He said it is very crude without any audio filters but it works.
The 19kHz pilot tone and the 38kHz multiplexing must have accurate frequencies. Lookup the required accuracy in Google.-Won't the encoder work if I use 4.00Mhz or 4.096MHz Xtal instead of 4.860Mhz? What will happen?
Use a dual opamp instead then you can reduce the gain easily.may I use your pre-emphasis for this encoder?
It is simple. Harry almost did pre-emphasis but his values were wrong. I have attached a pre-emphasis circuit.I hope that it is simple but I cannot figure out.
(Also, there is already an opamp in encoder.)
No. It is lousy and old.Will a dual opamp (eg. LM358) work as pre-emphasis?
4.860MHz is a little too low.Newark in America lists 700 quartz crystals. It has none at those frequencies so it must be custom made.
The wrong frequency crystal might work with some analog FM stereo radios but might not work with newer digital FM stereo radios.-Yes there are no 4.864MHz crystals. But 4.860 MHz may work, isn't it?
I forgot to attach my schematic last night. I added it this morning.where is the attachement?
Yes if you power and bias it correctly.Should I replace LM358 from his schematic with TL072?
No.I found few opamps- TL592 and LM386, won't it work as a TL072?
On the attachment to my last post I fixed the stereo pre-emphasis. I don't like the high impedance adder at the output of harry's encoder circuit. An opamp added to it will fix it.I want to make harry's encoder, show me the schematic improving all his faults please. I have sent email to Harry ''harryvpo(at)hotmail.com'' asking about suitable transmitter for this encoder and then I will show you again.[/i]
I think TL072 opamp has also 8 pins and according to your schematic, I can simply replace with previous LM358?
Yes of course. A TL072 is a much better dual opamp. It has the same pins, it has low noise and extremely low distortion and works well up to 100kHz.
Feedback resistor to control gain means....just like an attenuator? Should i have to decrease the value of it to....
Everybody except you know that the feedack resistor value in an opamp circuit controls the amount of voltage gain. It can attenuate instead of have gain if you calculate the resistor value.
Please do not post more unless you learn about the basics of electronics and the basics of opamps.
Didn't you go to school like everyone else??Goodbye. You know nothing about electronics.I think the 3rd resistor from lelt is a feedback resistor. And I think, according to your bias, now I can connect normal LINE OUT stereo audio from mp3 players or PC, isn't it?
Goodbye.I found a oscillator which is connected to stereo encoder. I think I can use this oscillator with Harry's coder too. Check this schematic but there is also a capacitor connected base to ground.
what about it?
No, my 2 friends also don't know about feedback resistor.Everybody except you know that the feedack resistor value in an opamp circuit controls the amount of voltage gain. It can attenuate instead of have gain if you calculate the resistor value.
Please do not post more unless you learn about the basics of electronics and the basics of opamps. Didn't you go to school like everyone else??
I looked in Google for FM Stereo Encoder Circuit and found many old circuits that are better than Harry's old circuit.
One has the proper filters but uses an awful old 555 as the main oscillator instead of a crystal oscillator.
