can any on esuggest how to program a PIC16F84 using C
subrat nayak
ie all the steps from
writing code in c
converting to hex code
loading on to the pc: hardware and software required
subrat
Basically it depends on what C compiler you buy, and if it's a DOS or Windows compiler.
If you use the MicroChip C compiler, and their PICStart+ programmer, it's all done from within MPLAB.
if you have some knowledge of programming in C with PCs then you will be up and running in no time. just study the documenatation of your compiler and see the example programs that it comes with and start writing codes yourself. the compiler will generate the hex code which can be used to burn on the chip.
there are a number of C compilers for PIC micros out there. namely IAR (very very very expensive), Hitech's PICC, CCS C and mikroC (its going to be released on the 7th of Feb this year)
all compilers have a code size limited trial version available that can be downloaded from their site. search on google for more info and go to the following link
https://www.microchipc.com
There's a 'student' version of microchip's C18 available on their website. That pretty much works great! :D
