So if piston face position and timing in relation to valve actuation is not key what exactly are you comparing in the timing alignments between crankshaft and camshafts to and for?
I'm curious to know if there is more to an engine's performance than just how the pistons and valves work together in an IC engine being that as I have ever understood it the goal to make them work together the most effectively as possible to achieve the desired end results?
I'm pretty sure I can't just toss a cam or cams in an engine at various random settings with no accurate alignments to the crankshaft and other key rotating parts and make an engine work.
Or can I and I and millions of other engine builders have been doing a lot of precision measuring fussing over nothing all these years?
