Cantafford
Hello,
I'm trying to make(in simulation not hardware) an analog to digital current converter. I'm using a LM134 current source: datasheet here.
I want my current source to output a current that can be set in the range: 2uA-100uA. On the "Calculating RSET" section from the datasheet it gives the formula. I looked at the electrical characteristics and put the parameters in the formula for RSET and arrived at a value of 13k ohms(I took the voltage as 1.2 volts)
Here's the RSET section of the datasheet:
Please note that this is my first time trying to calculate a value based on a datasheet ever so maybe there are noobies mistakes that I made. I would like if possible someone to tell me if I have calculated the value of RSET correctly and if with that value I will have a current in that range(2uA-100uA). Thank you for reading!
