C18 has any one had this happen
be80be
The file in there it gust will not use it
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F452 "main.c" -fo="main.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Documents and Settings\burt\Desktop\first project\main.c:5:Warning [2066] type qualifier mismatch in assignment
Executing: "C:\MCC18\bin\mplink.exe" "..\..\..\..\MCC18\lkr\18f452.lkr" "main.o" /u_CRUNTIME /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /m"gr1.map" /w /o"gr1.cof"
MPLINK 4.30.01, Linker
Copyright (c) 2009 Microchip Technology Inc.
Error - could not find file 'c018i.o'.
Errors    : 1
Link step failed.
Debug build of project `C:\Documents and Settings\burt\Desktop\first project\gr1.mcp' failed.
Preprocessor symbol `__DEBUG' is defined.
Sat Mar 21 13:32:04 2009
AtomSoft
dude your path is toooooo long lol
If thats not the issue then try remaking the project like create a new one and add your files to it. Try to use a path with no spaces and not too long. and rebuild it
felis
This is Microchip classic. They introduce this bug regularly. The linker library path is not set; go to project settings, directories tab, then make a new entry for library path pointing to the lib/ in MCC18 tree.
I don't have MPLAB in front of me at the moment so I'm writing from memory. Should you have difficulties following that, let me know.
be80be
This is same place as C18 and I have added all files and it will not use them
Debug build of project `C:\first project\gr1.mcp' started.
Sat Mar 21 13:59:47 2009
Clean: Deleted file "C:\first project\gr1.mcs".
Clean: Done.
C:\first project\main.c:5:Warning [2066] type qualifier mismatch in assignment
Executing: "C:\MCC18\bin\mplink.exe" "..\MCC18\lkr\18f452.lkr" "main.o" /u_CRUNTIME /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"gr1.cof" /M"gr1.map" /W
Errors    : 1
Link step failed.
binzer
I had the same problem, here is the solution from pommie.
From the C18 getting started guide,
EM-2 Linker error: “could not find file ‘c018i.o’”
Enter the proper directory path in Project>Build Options…>Project General tab. Set
the Library Path box to “C:\mcc18\lib”. c018i.o is the start-up library for MPLAB
C18. It sets up the stack, initializes variables, then jumps to main() in the application.
be80be
There is no
in C 18 4.30 I found where that is now I'm getting this
Make: The target "C:\c18\main.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F1220 "main.c" -fo="main.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\c18\main.c:5:Warning [2066] type qualifier mismatch in assignment
Make: The target "C:\c18\gr1.cof" is out of date.
Executing: "C:\MCC18\bin\mplink.exe" /l"C:\MCC18\lib" /k"C:\MCC18\lkr" "..\MCC18\lkr\18f452.lkr" "main.o" /u_CRUNTIME /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"gr1.cof" /M"gr1.map" /W
Error - processor types do not agree across all input files.
Errors    : 1
Link step failed.
be80be
I got it you got to add the whole ball of wax looks like they would work better
mplab 8.20 and c18 4.30
binzer
Yup, integrate C18 into Mplab, works good from the little I have done so far.
The other error looks like you have defined a processor twice and it's not the same one..
I keep getting bitten by the first one, not sure why..:eek:
Mike
be80be
o 18F1220 in MPLAB but you use a linker script for 18F452
I no that I change that Do you have 8.20 mplab and C18 4.30 the documentations for it doesn't mach the ide I got it to work I no I set the linker wrong on this computer but I had it set the same on the 1 I posted first on but I came down here to see if it would work see when i installed C18 it ask to set linker and the rest of it up so you don't have to add it didn't work
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F452 /i"C:\MCC18\h" "main.c" -fo="main.o" -D__DEBUG -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Errors    : 0
MP2HEX 4.30.01, COFF to HEX File Converter
Errors    : 0
Loaded C:\c18\gr1.cof.
Debug build of project `C:\c18\gr1.mcp' succeeded.
Sat Mar 21 17:01:14 2009
BUILD SUCCEEDED
felis
What language is that?
BTW, the output you posted says that your code compiled fine.
EE World Online Articles
Loading
