C Bit Access
Suraj143
Active Member
I have a variable called temp1.I need to check its bits individually.
The below code works for SFR.
if(PORTB.B0==1){.....}
But it won't work for GP registers.It gives an error "Operator '.' is not applicable to these operands 'temp1'"
if(temp1.B0==1){.....}
The generic way to check a bit is with a bitwise and.
if(temp1&0x01){.....}
or in binary
if(temp1&0b00000001){.....}
Some embedded c compilers will let you do a struct with bit fields. The definitions in the C18 processor header files are an example of that.
extern          near struct {
  unsigned C:1;
  unsigned DC:1;
  unsigned Z:1;
  unsigned OV:1;
  unsigned N:1;
} STATUSbits;
But I if you stick with the method above it will work on all c compilers.
