byte reversal code - need help understanding!
facemanfacey
hi all, i acquired a piece of code from a website which reverses a byte of code and i am having a little trouble understanding it. could anyone explain to me why he is swapf x,w in the first line, the xorwf x,w in the second line? in my (very shallow) understanding, wouldn't what just return the code back to its original form?
thank you
(i tried to format the code as good as possible)
thomas
; input X = abcdefgh , Output X = hgfedcba
; Written by Dmitry A. Kiryashov 2000
; 12 clocks/words
reverse8bit:
swapf X,W ;efghabcd
xorwf X,W ;efghabcd
;abcdefgh
andlw 0x66 ;.fg..bc.
;.bc..fg.
xorwf X,F ;afgdebch
rrf X,W
rrf X,F ;hafgdebc
andlw 0x55 ;.a.g.e.c
addwf X,F ;h.f.d.b.
;a.g.e.c.
rrf X,F ;.h.f.d.b
;.a.g.e.c
addwf X,F ;ahgfedcb
rlf X,W
rlf X,F ;hgfedcba
;it can be replaced
;with rlf X,W
;if necessary...
Total Program instructions: 7 + 19 Total instructions executed: 13
facemanfacey
pfft, sorry, i tried to format the code but it just reverted back to its original form... i could also be doing with some help with that aswell!
sorry and thanks
thomas
ericgibbs
Most Helpful Member
What you need to do is, post the code, select it, then click the '#' sign in the menu bar... keeps the formatting.:)
; 12 clocks/words
reverse8bit:
	swapf	X,W		;efghabcd
	xorwf	X,W		;efghabcd
;abcdefgh
;.bc..fg.
	xorwf	X,F		;afgdebch
	rrf	X,W
	rrf	X,F		;hafgdebc
	addwf	X,F		;h.f.d.b.
;a.g.e.c.
	rrf	X,F		;.h.f.d.b
;.a.g.e.c
	addwf	X,F		;ahgfedcb
	rlf	X,W
	rlf	X,F		;hgfedcba
;it can be replaced
;with rlf X,W
;if necessary...
bigsmooth
I don't know the assembly instructions that you are talking about, but I can show you how I do it in C.
char Reverse8(char x)
    x = ((x >> 1) & 0x55) | ((x << 1) & 0xAA);
    x = ((x >> 2) & 0x33) | ((x << 2) & 0xCC);
    x = ((x >> 4) & 0x0F) | ((x << 4) & 0xF0);
    return x;
int Reverse16(int x)
    x = ((x >> 1) & 0x5555) | ((x << 1) & 0xAAAA);
    x = ((x >> 2) & 0x3333) | ((x << 2) & 0xCCCC);
    x = ((x >> 4) & 0x0F0F) | ((x << 4) & 0xF0F0);
    x = ((x >> 8) & 0x00FF) | ((x << 4) & 0xFF00);
    return x;
I'll give you an example of what the 8 bit function does:
Original: 01101011
Step 1)
(x >> 1) = 00110101
AND with 01010101 (0x55)
result: 00010101
(x << 1) = 11010110
AND with 10101010 (0xAA)
result: 10000010
OR the results: 10010111
Step 2)
(x >> 2) = 00100101
AND with 00110011 (0x33)
result: 00100001
(x << 2) = 01011100
AND with 11001100 (0xCC)
result: 01001100
OR the results: 01101101
Step 3)
(x >> 4) = 00000110
AND with 00001111 (0x0F)
result: 00000110
(x << 4) = 11010000
AND with 11110000 (0xF0)
result: 11010000
OR the results: 11010110
Compare that to the original and you will see the bits have been reversed. The same logic applies to the 16 bit swap. The assembly code you've listed is doing the same thing.
EE World Online Articles
Loading
