Buzzer mode relay circuit equivalent with transistor ?
Externet
Hi.
How would you make the simplest equivalent circuit of a buzzing relay, by using a transistor ? Should work with 3V.
A-------------------relay coil--------------C----NC-------------------(+)3Volt(-)-------------------------B
When A contacts B, the normally closed contacts chatter.
Instead of the relay; how to do it solid state ? Anything between 100 Hz and 1000Hz is fine.
A blocking oscillator one transistor and a small transformer.
A unijunction transistor
A single transistor RC oscillator (Wein Bridge or other topology)
A two transistor multivibrator
A 555
