I would like to build a power supply to opperate some 60 volt DC servo motors which will be controlled by means of pulse width modulation. The controller boards are rated at 100 volts and 20 amps maximum **broken link removed** . I have in my garage the electrical componants from several photo copiers (a great source for small stepper motors bty) which are loaded with usefull looking parts. For my first question, I have noticed numerous parts labeled as noise filters, are noise filters the same as capacitors? I will need to rewind the secondry windings to get an output of 60 volts rectified, I have heard that rectifying ac to dc will lead to a voltage increase on the dc side, if this is correct can someone tell me how to calculate what the change will be? How do I limit the amps going to the controller boards to 20 without affecting the 60 volts dc (the motors use 3.5Amps continuous and 27amps peak)? I have seen on the net various diagrams of rectifiers which have a componant which looks like a centre tapped transformer, I have also seen a diagram of an automotive alternator which is simpler design comprising of a basic circuit with 4 diodes, is it ok in this situation to run with the simple alternator type system? I have also heard that it is ok, or even desirable to have more voltage available to the servo boards than the rated 60 volts of the motor, is this correct and can problems arise if the motor is being heavily loaded with excess voltage available at the board and how much extra voltage is safe?
Splint
Splint
