build digital ac voltmeter...please help
marvilos
hi all,
please help me...
is there any one has digital ac voltmeter 100 VAC - 250 VAC and i can read the reading by using microcontroller...?
or maybe u know the good web site about it,please let me know.
thx's
Basically you use a DC A2D, and convert the AC to DC using a precision rectifier circuit - you then calibrate it for correct reading on a sinewave. If you want a true RMS reading, then you can buy specific (fairly expensive!) chips that will do that for you.
For a crude meter, which presumably is all you need? - you could use an attenuator followed by a simple bridge rectifier with a small capacitor, feeding the analogue input of a PIC (or other micro-controller).
yes......i have build voltmeter but dc voltmeter and using ADC.
i still can't find on google how to make precision rectifier and calibrate it....
please let me know if you have links about this
thank you Nigel for reply me
A simple google finds this as the first hit **broken link removed**.
To calibrate it, simply adjust the input attenuator to make it read correctly, you will need another accurate meter to calibrate it against, or a known accurate voltage.
