Bright Lamps for Sign?
arrow
Hi
I am trying to build a sign with two lamps: one white and one red.
I have been trying to use an LED (the 5mm one seems brighter than the 10mm one). Can someone please recommend how to do this? I would like to have the light be as bright as possible and at least 25mm in size.
Thank you in advance.
a.
arrow
Hi
I have an led (super bright) and I would like to make it into a "torch". i.e. say its real dimension is 5mm in diameter a person standin say 10meters away, I want him to see it as say a 30mm or even a 40mm diameter light (be it white or red).
Would you have any suggestions on this?
Thank you
a.
lord loh.
How do you want the illumination? From behind the sign or to be reflected from the sign?
You can get reflectors for LEDs... So I have heard... but have never seen one myself. Moreover, LEDs have an angle of viewing... 15deg or 30deg or so...
For your application, wider the better as you can get the intensity by placing the LED closer.
You can use the LED + reflector like a battery powered torch and paste a translucent sign on the glass...
Good Luck.
arrow
Hi
I want to have the bright light attached to behind the board shining out. ie people looking at the sign board will be able to see the light.
Could you please tell me
(a) the name of the led reflectors
(b) will any led work with these reflectors?
Thank you
a.
andy257
funny enough i seen the insides of those pedestrian crossings attached to lamp posts. All they have to illuminate the "WAIT" sign is what looked like a 60W bulb powered from the mains supply. Not saying you have to adopt the same thing but maybe depending on your application you could use the mains to power some lighting. Most signs ive seen, outdoor ones anyway are wired into the mains.
just a thought
Andy
arrow
Hi
I can use the main power- but I dont know how to implement a switch that is controlled by a microcontroller?
Thank you
a.
Nigel Goodwin
Super Moderator
Most Helpful Member
arrow said:
Hi
Either use a relay, or a triac - you can also buy solid state relays, which are basically a triac and the associated circuitry.
moody07747
arrow said:
Hi
Thank you
a.
A) I would think they are called LED reflectors
B) You must match the size of the LED with the reflector as the reflector slips over the LED like in the every day flashlight.
some searching on yahoo came to this
http://www.theledlight.com/led-specs.html
heres a whole LED/Reflector assembly (expensive)
http://www.theledlight.com/panelmount.html
some cluster LED panels
http://www.theledlight.com/led-assemblies.html
this guys got an Idea
http://www.sentman.com/led/durabeam.php
Reloadron
Most Helpful Member
I know this maybe an old thread but I got similar problem. I really need a tutorial for this. :(
What exactly are you trying to do? Exactly means in detail so people can understand what you want and provide workable solutions.
Ron
alec_t
Most Helpful Member
I think that to illuminate a 40 x 40 mm area uniformly an array (4 x 4 ?) of ordinary 5mm LEDs behind frosted plastic/glass sheet would be better than a single LED. They're cheap enough, and possibly cheaper than a LED + reflector. A simple wall-wart, plus current-limiting resistor(s), could power them.
BrownOut
Banned
I can't even understand what the problem was. Can you explain in full detail?
DerStrom8
Super Moderator
Hi euhero987. Welcome to ETO :)
It probably would have been better to start a new thread, rather than adding onto one that is 5 years old. If you go to the main forum page, select the correct forum, and click the button "create new thread", I'm sure you'll be better off.
Good luck!
Der Strom
EE World Online Articles
Loading
