Bridge rectifier question
220VAC goes from 0V to its peak of -311V through 0V to +311V then repeats.
When it is rectified then the voltage goes from 0V to +309V then repeats over and over.
If you add a filter capacitor to the rectifier then you have 309VDC.
You need a circuit to convert 309VDC to only 220VDC.
It depends on what you want 220VDC for.
If all you want to do is power a permanent magnet motor, then use a bridge rectifier with no filter capacitor. For safety's sake you'll need to connect the motor's frame to earth, along with any other exposed metal work the encloses mains connections.
The rms value, that is, the heating value into a resistor, of full wave rectified sine pulses is the same as the rms value of the input AC, minus a 2v total drop for the diodes.
Half wave DC is a little trickier.
No it's not it's just half the RMS value of the input waveform minus 1V for the diode.
I forgot to say that if you're using this to power a PM motor then it's a good idea to add a reverse parallel diode to the motor to protect the bridge rectifier from the back EMF.
