I am trying to get a zener diode to work with no interruptions off rectified AC mains, using this schematic:
The problem is although there is a large 100uF filtering cap, when the positive side of the zener is close to negative and the negative side of the zener is very negative the zener shuts off and the zener voltage goes to zero. However, the way I am measuring it (+ minus -), the different voltage of the zener cap is still large. Hard to explain with words but here is what the waveforms look like:
Node 1 (CH1, CH2, and Math which is CH1 - CH2):
Node 2 (CH, CH2, and Math @ 50V/div):
Node 2 at 20V/div (now you can see the zener turning on and off):
