Brand new Motor speed controllers (PWM) getting real hot
kal.a
I purchased a CanaKit like the one in this link and I correctly wired it to a 12VDC and did not wire any load to it. As soon as I turn the power on it gets quite hot that it is almost melting. After the first time I tried a few more times but for a second or two just to measure the output at M- and M+ without load and got almost 0 volts. Any ideas what I'm doing wrong?
I think you may have to have a load connected, wire a motor up to it and try again.
Plus your multimeter may not be able to read the o/p, you really need a meter that will measure duty.
Did you fuse the input?
Did you contact tech support?
Did you connect a fan?
Does it recommend a snubber?
I think the battery or power supply should be close to unit otherwise a low ESR cap may be necessary on unit.
Tech support is your best bet.
Thanks guys.
I'm using a 4 Amp transformer and a NTE53020 rectifier1000V,50 A and they're all right there with the controller. No more than a foot of wire.
No fan though one is available as an option
@kal.l that power source does not satisfy the requirements as given.
What caps are used and what voltage? ripple? You better use a 12V battery if it is not damaged already.
Hi Tony,
Why do you say it doesn't satisfy power requirement? 12VDC and 4 amp transformer with no load. I am not drawing anything from it yet. Please explain in as simple a form as possible as all this is new to me.
Kal
This unit shows no power conditioning and PWM switch mode drivers depend on a good DC voltage sources.
A transformer and bridge alone is an inductive source a switched load creates large voltage spikes which in turn can create false triggering.
If you are using 50 Hz then the bridge would output 100Hz.
Typically 10% ripple is allowed on input but may be excessive for this product.
If you are driving a motor it has a surge current of 5x to 8x times rated average.
Normally a resistive load only @4A needs almost at least 8 cycle time constant. or RC= 10x 1/100Hz= 1/10Hz ot 100ms time constant.
Using Ohm's Law 12V/4A=3 Ohms thus the demands for C from this type of supply are RC= 0.1sec or C = 0.1/ 3Ohms= 33,000 uF.
Then you need low ESR caps in parallel with this.
That's why I suggested a battery they are thousands of Farads. It can be float charged by your power supply to 13.8V
Although a better choice would be a SMPS such as a 350W PC PSU. ( almost free) using the HDD connectors.
"I purchased a CanaKit "
You either built it incorrectly or the parts are wrong or faulty.
Thanks Colin. The "kit" was put together and all I did was plug it in. But thanks for bringing up the thread as I just realized I unintentionally did not thank Tony for his detail and very informative reply. I believe he was right on the money and though my PWM is now no more, I was able to salvage four mosfets out of it:cool:
