I am using a function generator to deliver a signal to my ignition coil project but i need help with the post connector im using.
The front side of the plug is female BNC. The back side has 2 solder tabs, one on the outer casing and a copper center line.
Is it necessary to use coax and both solder tabs or can I just use some solid copper wire soldered to the center copper terminal of the BNC connector without the outer tab that the shielding would normally solder to?
