Centretek said:No potting mix will dissipate heat, in fact all of them insulate because they are poor conductors of heat. You can however fit strip heat sinks that extend outside the potting compound.
Surely they can't be worse conductors of heat than air? And since it's potting it's in direct contact with the electronics- it's not like sticking electronics inside a sealed box where the air can't circulate and just gets hotter and hotter. In this case the heat source is in direct contact with the potting compound which is then transferring the heat to the air. I would think it improves cooling. Usually you don't stick hot things in enclosed AIR spaces because the air is a terrible thermal conductor and can't circulate. BUt if you're surrounded by something that is a better thermal conductor than air, it's completely different. Surely you don't think that if potted some electronics in some kind of magical non-conductive metal that it would run hotter? Almost anything is a better thermal conductor than air.Centretek said:No potting mix will dissipate heat, in fact all of them insulate because they are poor conductors of heat. You can however fit strip heat sinks that extend outside the potting compound.
