carolineannsam
I am doing a project on 3 phase bldc motor (24V,1.5 A)control using pic18F4431.Power circuit is implemented using driver IC IR2110 and 3 phase inverter with a total of six MOSFETs (IRFz44N) .BLDC motor works with three hall sensor feedbacks...For a particular sequence (for eg.001) one top switch and one bottom switch should be ON..Then only, a particular winding of the motor(for eg phase ab)will be energised and the rotor will move.The problem is that i m getting only LO output of the driver IC .So the rotor is just shivering...and it is not rotating... can any1 help me?
