Bit Select
jbchrist
Ok....This should be an easy question, but I can't find the answer because I don't know what to look for.
I am writing a program for a PIC16f684, using the PIC C lite complier.
I have a 8 bit value stored and I want to take bit x and store it in a different variable.
How do I do that?
John
I would guess,
NewVar = OldVar&(1<<X);
Would issolate the bit. (X = 0 to 7)
Edit changed the operator to the bitwise one as PB pointed out.
Note to self, don't post at 2AM after a night out.:eek:
Using the && relational operator with an actual C compiler would be a pretty hard bug to find. You should use the bitwise & operator which will get you the intended result.
I would also highly recommend that you examine carefully the compiler's assembly language output to verify that it is doing what you want it to do.
