Bit banging with C
Mejinx
Im trying to bit bang for a lab with the pic18f452 without using use RS232 but i wanna write it in C. How would i go about doing this? thanks
The 8051 C compilers I've used have non-standard extensions to C to do sets and clears on bit addressable memory.
A good compiler should recognise something like:
PORT |= 0x01;
as a set bit instruction. Try it and look at the disassembly to see what this C line translates to.
It's a fine example of why you should use assembler, it's trivial to do, and only takes a few lines.
