binary to bcd decoder
This is only true if your number is 9 or less. Otherwise, you must decode if you want bcd.samcheetah said:first of all i dont understand the subject.
BCD is binary coded decimal. so BCD is actually an encoded form of binary. u cant decode binary to bcd. although u can decode bcd to binary.
11011011 (binary) = 219 (decimal) = 0010 0001 1001 (bcd). That requires a decoder
Isn't that called semantics? I thought you were implying that no logic transformation (encoding, decoding, transmogrification, whatever) was required to get from binary to BCD.
OK, sorry that I misunderstood you. I generally agree with your definitions of encoding and decoding, although a Google search for "binary to BCD decoder" produced a page of hits - so I'm not the only idiot. :?samcheetah said:Isn't that called semantics? I thought you were implying that no logic transformation (encoding, decoding, transmogrification, whatever) was required to get from binary to BCD.
when u transform one thing into something else, it is called encoding and when u transform it back to that thing it is called decoding. so when u transform binary into BCD, u r encoding binary into BCD. so BCD is an encoded form of binary. now when u transform BCD to binary u are decoding BCD to get the equivalent binary. the person who asked the question wrote "binary to BCD decoder" in the subject. so i told him that he was not right.
i think we should not argue on semantics and rather try to answer his question.
i told that im sorry i dont understand the question. but i did try to answer the question from what i understood.
The binary to BCD converters I have seen require a microcontroller or microprocessor. There was a TTL part, 74185, but it seems to have been discontinued.
If you had a multi-digit BCD counter, and you converted the output to binary, would that be called an encoder or a decoder? I think perhaps "converter" is a better term, no matter which way you are going.
jacuinde said:i have a problem, im representing a analog signal that im converting it to digital, then when i try to display on a 7 segment display with a 7448 bcd driver, a 10, i want it to turn to 0 and that in another display it gives me a 1, how can i do it?
