Best accelerometer for balancing robot
Probably the most sensitive one. The mounting place of the sensor is more important than the sensor itself. How big is your balancing robot?
Very difficult to give answers with so little information. Choose the most sensitive 2 or 3-axis accelerometer from the cheap end of the price end. Make sure that the sensor has an interface that you can use (analog, i2c, spi).
Try to find a module that is already soldered to a pcb because most of the accelerometers are in very small "no-leads" packages and are therefore difficult to solder (for hobbyist).
https://www.pololu.com/search?query=accelerometer&x=0&y=0
Edit: This could be a good choice if analog output interface is ok for your product: https://www.pololu.com/catalog/product/1246
yes,
i want to build two wheel self balancing robot,
with geared dc motor, at a size, which can be easily balanced,
later i want to mount other parts to the robot with the self balanced base as the basement for the robot.
I used one of these for a robotics project recently and it proved very sensitive and easy to use. If you leave the g select pin disconnected it will be in 1 g mode, besides that just give it power and pull the slp (sleep mode) pin high to turn it on.
https://www.sparkfun.com/products/9652
Hey...
I can advise you ADXL series , i tried that before in some projects related to heading and balancing UAVs. you can check for more details according to your needs.
