Battery Level Indicator
AceOfHearts
Hi every one,
I want to implement a simple battery level indicator, the level will be displayed on GLCD.
I have no idea on how to implement the hardware that measures the battery level. First of all, what are we measuring, is it the battery voltage level?
I need to measure 8AA batteries that is giving 12V.
Many thanks for any info and circuit diagrams.
PS. I know how to control the GLCD...its just building a suitable circuit to measure the battery level and reading this with the microcontroller connected to GLCD (which suggests that readings will have to be digitised...which means an ADC somewhere? )
Regards.
From the 12V, I would assume you are talking about alkaline batteries as Ni-Cads and NmH usually measure 9.6V.
Hi k7elp60,
Yep its Alkaline batteries indeed. :)
Go to the Microchip web site, and in the search box at the top right of the page enter: DS41215C, and check all documents.
Guess what? Tip #1 tells you how to do what you want to do.
By the way, while you're there, familiarize yourself with all their self-help documents. There's a ton of information available on everything from 12-bit Base products all the way to dsxxxx.
Go to www.energizer.com and look at Technical Info where thy hava a datasheet for each battery.
The voltage depends on how much current is being drawn and on how much capacity of the battery is left.
8 new AA alkaline batteries are 12V. If the load is 1A then the voltage quickly drops to 10.4V in about 15 minutes and drops to 8.0V in about 1 hour.
If the load current becomes less then the battery voltage increases. If the load current stops then the battery voltage might become 11.8v or 12v again.
8 AA Ni-MH cells are 12V when fully charged but quickly drop to 9.6V. They drop to 8V in about 1 hour at 1A but can be charged over and over.
