Basic counter for a PIC16F877A...
triplestak
Hey, I'm new in here and was seeking some advice on a simple program I'm having to write for one of my Electronics classes. It's a basic program written for the PIC16F877A and bit zer0 (SW0) on the switch board (Port B) resets the outputs on Port A and the bit 1 (SW1) starts a count on the LEDs and increments them one value at a time. The code works fine in the MPLAB IDE debugger, but when I send the Hex file to the Control board, the reset button works and the run button only turns on the first bit or the bit zero LED, but it doesn't increment. Here is a copy of the code. Any help would be greatly appreciated...
list p=16f877a ; list directive to define processor
#include <p16f877a.inc> ; processor specific variable definitions
PORTA EQU 005h ;Port A Data Register
PORTB EQU 006h ;Port B Data Register
TIMER EQU 020h ;Spare register for delay
STATUS EQU 003h
TRISA EQU 085h
ADCON1 EQU 09Fh
inres EQU b'00000000' ;'Reset' input button SW0
inrun EQU b'00000001' ;'Run' input button SW1
bcf STATUS,RP0
bcf STATUS,RP1 ;Selects Bank 0
clrf PORTA ; clears port A
bsf STATUS,RP0 ;Selects Bank 1
movlw 006h
movwf ADCON1
movlw b'00000'
movwf TRISA ;Prepares port A for Output
bcf STATUS,RP0
clrf PORTA
movlw b'00000' ;Port A Data Direction Code
TRIS PORTA ;Load the DDR code into F86
goto reset
delay movwf TIMER ;is loaded into spare register
down decfsz TIMER ;decrement timer register
goto down ;and repeat until zero then
RETURN ;return to main program
reset clrf PORTA ;Clear Port A Data
start btfsc PORTB,inres ;Test SW0 input button
goto reset ;and reset Port A
btfss PORTB,inrun ;Test SW1 input button
goto start ;and run count if pressed
INCF PORTA ;Increment count at Port A
movlw 002 ;Delay count literal
CALL delay ;Execute delay subroutine
goto start ;Repeat main loop
END ;Terminate source code
You did not make the TRISB pins inputs! The fact that one button works sometimes is because you didn't clear port b and it's reading the 1's?
Next time use code blocks please!
Thanks...
I really appreciate it Birdman. Question, I was under the impression that most I/O ports default to input unless you specify otherwise. And when you say code blocks you mean the separation asterisks between different sets of code, correct?
D' means like this.... use the '#' option on the post menu to enclose your text to keep the formatting.
PORTA    equ    005h        ;Port A Data Register
PORTB    equ    006h        ;Port B Data Register
TIMER    equ    020h        ;Spare register for delay
STATUS    equ    003h
TRISA    equ    085h
ADCON1    equ    09Fh
inres    equ    b'00000000'    ;'Reset' input button SW0
inrun    equ    b'00000001'    ;'Run' input button SW1
    bcf    STATUS,RP0
    movlw    006h
    movwf    ADCON1
    movlw    b'00000'
    bcf    STATUS,RP0
    clrf    PORTA
    goto    reset
    return            ;return to main program
    incf    PORTA        ;Increment count at Port A
    call    delay        ;Execute delay subroutine
    end            ;Terminate source code
Not so far...
I tried what you said by adding this to the code:
bsf	 	STATUS,005h
	    movlw 	b'11111111'
        movwf 	TRISB
        bcf	 	STATUS,005h
Any other suggestions?
STATUS    equ    003h
TRISA    equ    085h
ADCON1    equ    09Fh
    bcf    STATUS,RP0
    movlw    006h
    movwf    ADCON1
    movlw    b'00000'
    bcf    STATUS,RP0
    clrf    PORTA
    goto    reset
Thank you so much for the heads up on the code blocks!!!
inres EQU 0  ;'Reset' input button SW0
inrun EQU 1 ;'Run' input button SW1
cblock 0x20
TIMER        ;Spare register for delay
TIMER1
endc
org 0x00
goto Init
org 0x04
retfie
Init:
clrf TRISA ;Prepares port A for Output
movlw 0xff
movwf PORTB
bcf STATUS,RP0
start:
clrf  PORTA;  reset Port A
movlw 255  ;Delay count literal
delay:
down:
decfsz TIMER1 ;decrement timer register
decfsz TIMER
goto down
end ;   Terminate source code
Moved a whole bunch around, made delay longer.
After this i think your problem would be hardware or configurations.
Update me!
