Audio source relay
demitrix
Wow this forum looks really promising, and if so then this should be a sinch for all you guys. What im looking to build is a way to switch between two audio sources, automatically. One output is an iPod and the other is a walky-talkie, now the tricky part. I need the iPod to play straight through to a headset, but when the radio chimes in I need the iPod to be bypassed and for the radios signal to play through to the headset. Its a single ear piece so i dont need stereo capabilities. Thanks much.
Usually a walky will have a COR light that comes on when it recieves a signal. You could wire the signal from this light to a small relay via a transistor.
If you don't want to MOD the walky, then you'll need a VOX circuit to trip the relay. Google for a VOX circuit.
Ha never thought about using vox, that would provide me with enough power to switch a relay, but my next question is, is a relay the best way to switch the audio sources or is there something else i could use, i want the device to be pretty small. Maybe using another comparator to actually switch the b/w the two sources.
I recall a simple squelch design that was simply a capacitor connected to the audio output of a weather radio. The no-signal noise output from the capacitor was sufficiently different from signal-present output to trigger or not trigger a mute circuit. You might employ a capacitor and LM339 or similar comparator to drive a relay.
A relay is probably the best solution. Trying to use an IC or something could lead to distortion etc. Whereas a relay phsically changes the connection.
They make some pretty small relays that would be able to handle this low power application.
Use a DG409 analog switch. Has high fidelity, and is used in data aquisition systems with high resolution with no problems.
Aight so if i combine the vox circuit with the DG409 i should be set to go then right? Ill draw up a visio schematic and post it to make sure im 100% sure on whats being described, Thanks for all the help...
Ok heres the schematic i ended up with in visio, only a few questions. For VCC that could be a 9v battery correct? And all the ground would be the negative terminal on the battery right? And on the DG408(which i chose for its single output) the V+ and V- could be just the battery + and - too correct?
The bottom half is a vox circuit i got from **broken link removed** i left out the resistance and such just for ease of looking at but everything is there.
For the 408 or 409, a bipolar supply is necessary if you have a signal that is bipolar. So if your audio source goes both neg. and positive, then you must have a +9, -9 on the chip, or whatever voltage you pick within its range.
How would i be able to generate the negative voltage, ive never dealt with it before, i quit EET after 1 term, kinda wish i woulda stuck around now.
The on-resistance of the DG408 is far too high to drive a speaker.
You would need a separate power amplifier to drive the speaker then any Cmos analog gate can switch the line-level signals to the amplifier.
Yes, I was assuming the OP was using line level signals.
