I'm trying to make a variable voltage power supply from an old ATX power supply I have laying around. The problem I'm having is finding voltage regulators that can handle both 1) high power and/or 2) regulation from 0-12 (or 0-24) volts. Any recommendations on regulators that meet these criteria, and can handle 10 or so amps? My plan was to bring out the regulated +12, +5, and +3.3 connectos, while making an additional variable voltage output. I'm thinking I'll skip the -12 volt connector because I've read that it can't handle high current, and what fun is a 300 watt ATX supply if it can't handle high current? On a less important note, without making a ringing choke or switching power supply (I'm worried that adding these might add unpleasant harmonics at my output), is there an easy way to generate 24 volts from the ATX supply to increase the versatility of my supply?
