hansmuller
Hello members,
The PSU was running when a lightning bolt struck far away. turned off and cannot power on again.
so probably overvoltage exposed.
I opened the PSU to replace the fuse. it is a ceramic one, therefore I cannot see at first sight if it is blown. Also removal seems unnecessarily difficult as it is soldered and no holders that may clamp it.
Did a sight inspection and did not see anything apparent.
As i do not have good soldering equipment, do you recommend to bring it to technician to solder replace the T10A fuse?
What else maybe should be checked before that?
with best regards
Hans
with best regards
Hans
