Attiny861 Duty Cycle variation
firstoption
Good day to all,
Please i need your support.I am Controlling Led brightness with PWM Signal and at the same time Displaying the duty cycle(represented in %) on an Lcd Display.The Problem i am having is that the percentage of the duty cycle shown on the oscilloscope is different from the value shown on my Lcd Display.For example when the oscilloscope showed 50% duty cycle the value shown on the LCD was 38%.I would be glad if somebody could help me have a look at my code may be there is something i am not doing correctly.Below are my lines of code.Thank you for the usual Support.
Best regards.
# define F_CPU 1000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/delay.h>
#include "NewHeaven_LCD.h"
#include "USI_TWI_Master.h"
#define SLAVE_ADDR  0x50
#define MESSAGEBUF_SIZE  20
#define TWI_GEN_CALL  0x00  // The General Call address is 0
// Sample TWI transmission commands
//#define TWI_CMD_MASTER_WRITE 0x28
//#define TWI_CMD_MASTER_READ  0x29
// Sample TWI transmission states, used in the main application.
#define SEND_DATA  0x01
#define REQUEST_DATA  0x02
#define READ_DATA_FROM_BUFFER 0x03
#define RTC_ADDRRESS  0x34 //0x68
#define RTC_REG_POINTER  0x00
unsigned char messageBuf[MESSAGEBUF_SIZE];
unsigned char TWI_DisplaySlaveAddress,TWI_RTCSlaveAddress, temp, pressedButton, myCounter=0;
unsigned char TWI_Act_On_Failure_In_Last_Transmission ( unsigned char TWIerrorMsg )
  // A failure has occurred, use TWIerrorMsg to determine the nature of the failure
  // and take appropriate actions.
  // Se header file for a list of possible failures messages.
  asm volatile ("nop");
  return TWIerrorMsg;
unsigned char Reset_RTC()
 messageBuf[0]=(TWI_RTCSlaveAddress<<TWI_ADR_BITS) | (FALSE<<TWI_READ_BIT);
  messageBuf[1] = RTC_REG_POINTER;
  messageBuf[2] = 0;
 messageBuf[3] = 0;
 messageBuf[4] = 0;
 messageBuf[5] = 0;
 messageBuf[6] = 0;
 messageBuf[7] = 0;
 USI_TWI_Start_Transceiver_With_Data(messageBuf,8);
 return 0;
int main( void )
  char  time_array[10];//HH:MM:SS
  unsigned char repeat=1;
  unsigned char sec,min,hr;
  unsigned char i,check=1;
  unsigned char mode=0;  // mode=0 : Power_Setting  ;;;; mode=1 : Time_Setting
  int LED_Power=1;
  int On_Time=0;
  int LED_on=0;
  int Duration=0;
  int RTC_Seconds=0;
  TWI_DisplaySlaveAddress  = 0x28;
  TWI_RTCSlaveAddress  = 0x68;
  sei();
  USI_TWI_Master_Initialise();
  messageBuf[0]=(TWI_DisplaySlaveAddress<<TWI_ADR_BITS) | (FALSE<<TWI_READ_BIT);  // Display an 0x28 schreibend ansprechen
  messageBuf[1]=0xFE;
  messageBuf[2]=0x53;
  messageBuf[3]=8;
  USI_TWI_Start_Transceiver_With_Data(messageBuf,4);
  // Set PWM-Port PB4
  PORTB = 0x00;
  DDRB  |=(1<<PB4) ;  //PWM output pin
  TCCR1A |= ((1 << PWM1B));  // Enable Fast PWM for OCR1B
  TCCR1C |= ( (1 << PWM1D) );  // Enable Fast PWM for OCR1D
  TCCR1C |= ( (1 << COM1D0) );  // OC1D & OC1D^ are connected,Clear on Compare Match
  OCR1C  = 77;
  OCR1D  = LED_Power;
  //Invert output
  TCCR1B |= (1 << PWM1X);
  // Start timer1
  TCCR1B |= (1 << CS10)|(1 << CS11)|(1 << CS12);
  //Switch internal pullups on
  PORTA |= (1<<PA7) | (1<<PA6) |(1<<PA5) |(1<<PA4);
  PORTB |= (1<<PB6);
  Clear_LCD();
  for(i=0;i<8;i++)
  time_array[i]='0';
  time_array[2]=time_array[5]=':';
  /*Convert ASCII to BCD coded data and store in RTC registers*/
  for(i=0; i < 8; i++)
  if ((i==2) || (i==5))
  ;  //do nothing
  else
  time_array[i] -= 48;
 sec = (((time_array[6] << 4) & 0xf0) | (time_array[7]));
 min = (((time_array[3] << 4) & 0xf0) | (time_array[4]));
 hr =  (((time_array[0] << 4) & 0xf0) | (time_array[1]));
  /*Write data (time ) in RTC*/
  messageBuf[2] = sec;
 messageBuf[3] = min;
 messageBuf[4] = hr;
  USI_TWI_Start_Transceiver_With_Data(messageBuf,5);
  while(1==1)
 if (mode==0)  // Power_Setting
 if (!(PINA & 64 ))
 if (LED_Power>1) LED_Power--;
 else if (!(PINA & 16 ))
 if (LED_Power<100) LED_Power++;
 if (mode==1)  // Time_Setting
 if (!(PINA & 64 ))
 if (On_Time>0) On_Time--;
 if (On_Time<300) On_Time++;  // maximale On-time 5min
 if (!(PINA & 32))
 switch (mode)
  case 0: mode=1;
  break;
  case 1: mode=2;
  break;
  default:mode=0;
  break;
 _delay_ms(200);
 if (mode==0)
 {  SetPos_LCD(0,0);
 sprintf(lcd_text,"*Power One %d  ",LED_Power);
 WriteString_LCD();
  SetPos_LCD(0,1);
 if (On_Time) sprintf(lcd_text," Real Time %ds  ",Duration); else sprintf(lcd_text," On_Time Period  ");
 WriteString_LCD();
 _delay_ms(10);
 if (mode==1)
 {  SetPos_LCD(0,0);
 sprintf(lcd_text," Power One %d  ",LED_Power);
 WriteString_LCD();
 SetPos_LCD(0,1);
 if (On_Time) sprintf(lcd_text,"*Time One %ds  ",Duration); else sprintf(lcd_text,"*On_Time Period  ");
 WriteString_LCD();
 _delay_ms(10);
 if (!(PINA & 128))
  _delay_ms(200);
  if (LED_on==0) {LED_on=1; Reset_RTC(); RTC_Seconds=0;} else LED_on=0;
  if (LED_on) {OCR1D=50;  _delay_ms(1);}
 if (LED_on) OCR1D=LED_Power; else OCR1D=0;
 if (LED_on==0)
 Duration=On_Time;
 SetPos_LCD(15,0);
 sprintf(lcd_text," ");
 WriteString_LCD();
 else
 SetPos_LCD(15,0);
 sprintf(lcd_text,"*");
 WriteString_LCD();
 if ((LED_on) && (On_Time))
 if (RTC_Seconds>=On_Time)
  LED_on=0;
 else
 Duration=On_Time-RTC_Seconds;
  // Set RTC Register
  USI_TWI_Start_Transceiver_With_Data(messageBuf,2);
  // Read RTC Register
  messageBuf[0]=(TWI_RTCSlaveAddress<<TWI_ADR_BITS) | (TRUE<<TWI_READ_BIT);
  sec=messageBuf[1];
  // Set RTC Register
  messageBuf[1] = 0x01;
  min=messageBuf[1];
  // Set RTC Register
  messageBuf[1] = 0x02;
  hr=messageBuf[1];
  // convert time to seconds
 RTC_Seconds=  (sec & 0x0f) + 10* ((sec >> 4) & 0x0f)  // seconds
  + 60*(min & 0x0f) + 600*((min >> 4) & 0x0f); // minutes to secs
  // convert BCD coded decimal to ASCII code, display on LCD
  time_array[0] = (hr >> 4) & 0x0f;
  time_array[1] = hr & 0x0f;
  time_array[3] = (min >> 4) & 0x0f;
  time_array[4] = min & 0x0f;
  time_array[6] = (sec >> 4) & 0x0f;
  time_array[7] = sec & 0x0f;
  for(i=0; i< 8; i++)
  ;  //do nothing
  else
  time_array[i] += 48;
  time_array[8]=0;
  //SetPos_LCD(0,1);
  //sprintf(lcd_text,"Second %s  ",time_array);
 //sprintf(lcd_text,"seconds %d  ",RTC_Seconds);
  //WriteString_LCD();
  //  OCR1B=64;
