HI ALL
anyone use avrs i found some code that does What Written this programe.
thanks in advance..
AvrStudio
include "m88def.inc" ; Processor
definitions
.include "system_macros.inc" ; Register allocation, processor specific
.include "rom_table_init_simple.gen" ; Created automatically
.include "stepper_cfg_simple.inc" ; Configuration for specific motor
.include "pin_macros.inc" ; I/O definitions
.include "bridge_macros.inc" ; Bridge control
.include "curr_reduction.inc" ; Current reduction
.include "decay_macros.inc" ; Decay control algorithms
.include "table_macros.inc" ; ROM & RAM table processing
.include "da_macros.inc" ; D/A converter support
;************************ Initialization ****************************
;** Watchdog initialization
; WATCHDOG_INIT_SLOW
;** Stack initialization
STACK_INIT
;** I/O initilization
CONFIGURE_IO_PORTS
BRIDGE_A_DISABLE_FAST
BRIDGE_B_DISABLE_FAST
;** SPI initialization
SPI_INITIALIZE
;** Timer initialization for idle timeout
CURR_REDUCTION_INIT
CLEAR_CURR_REDUCTION_TIMEOUT
;** Initialize step configuration
ROM_TABLE_INIT
;** Initialize decay control
CMP_DECAY_INIT
CMP_DECAY_PREPARE_NEXT
;** Change watchdog timeout from init mode to operational mode
; WATCHDOG_INIT_FAST
; *************** Microstep common control loop ********************
main_loop:
wdr
; 'Enable' signal processing
CHECK_ENABLE
cpi temp,0
brne enable_is_high
enable_is_low:
; check for change from 'enable' to 'disable'
clr temp
cp ENABLE_MODE,temp
breq main_loop
; Ok, this is a change from 'enable' to 'disable'
; We need to disable bridge control
; and setup D/A converter to 'adjust' mode
SPI_TRANSFER_ADJUST
rjmp main_loop
enable_is_high:
; check for change from 'disable' to 'enable'
clr temp
cp ENABLE_MODE,temp
brne enable_continue
; Ok, this is a change from 'disable' to 'enable'
; We need to update D/A converter (from 'adjust' mode )
; and reenable bridges
SPI_TRANSFER
BRIDGE_A_ENABLE
BRIDGE_B_ENABLE
inc ENABLE_MODE
enable_continue:
; Check if current reduction should be applied
CHECK_CURR_REDUCTION
cpi temp,0
breq no_current_reduction
SPI_TRANSFER ; execute current reduction
no_current_reduction:
; Process comparator inputs
CMP_DECAY_CHECK_A
CMP_DECAY_CHECK_B
; Check if next step should be executed
CHECK_STEP
cpi temp,0
brne step_to_make
rjmp main_loop; no next step (to large distance for relative branch)
;******************* Step initialization *************************
step_to_make:
; Next step should be executed - load new step data
ROM_TABLE_STEP
; Execute transfer to D/A converter
SPI_TRANSFER
; Execute new bridge control
BRIDGE_A_ENABLE
BRIDGE_B_ENABLE
; Prepare new decay control
rjmp main_loop
; ********************* ROM step tables ******************************
#include "rom_table_data_simple.gen" ; Created automatically
; in externl tool
; ********************* RAM step tables ******************************
.dseg
sinus_table_step:
.byte (STEP_NUMBER * 2)
sinus_table_step_half:
sinus_table_step_end:
decay_table:
.byte (STEP_NUMBER * 4)
decay_table_end:
thanks in advance..
AvrStudio
definitions
STACK_INIT
CONFIGURE_IO_PORTS
SPI_INITIALIZE
CURR_REDUCTION_INIT
ROM_TABLE_INIT
CMP_DECAY_INIT
main_loop:
wdr
CHECK_ENABLE
cpi temp,0
brne enable_is_high
enable_is_low:
clr temp
cp ENABLE_MODE,temp
breq main_loop
SPI_TRANSFER_ADJUST
rjmp main_loop
enable_is_high:
clr temp
cp ENABLE_MODE,temp
SPI_TRANSFER
BRIDGE_A_ENABLE
BRIDGE_B_ENABLE
inc ENABLE_MODE
enable_continue:
cpi temp,0
CMP_DECAY_CHECK_A
CMP_DECAY_CHECK_B
CHECK_STEP
cpi temp,0
brne step_to_make
step_to_make:
ROM_TABLE_STEP
SPI_TRANSFER
BRIDGE_A_ENABLE
BRIDGE_B_ENABLE
rjmp main_loop
; in externl tool
.dseg
sinus_table_step:
decay_table:
decay_table_end:
