Assembly project with pic16f887 lcd and special character generation
runman_up
does anyone know the assembly code for pic 16f that can generate the special CGRAM character codes - I suspect it is fairly straightforward - I just don't know it - -
thanks
Richard
This should be all you need to get started.
For the LCD commands, check Nigel's site;
UDG					;User defined graphics
	call	LCD_Init
	movlw	0x40	;CGRAM Address
	call	LCD_Cmd
;----------User defined bit------
;-------------0x00---------------First character
movlw	 0x0E
call	LCD_Char
movlw	 0x11
call	LCD_Char
movlw	 0x11
call	LCD_Char
movlw	 0x11
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1B
call	LCD_Char
movlw	 0x1B
call	LCD_Char
movlw	 0x1F
call	LCD_Char
;-------------0x01---------------Second character
movlw	 0x0E
call	LCD_Char
movlw	 0x11
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1B
call	LCD_Char
movlw	 0x1B
call	LCD_Char
movlw	 0x1F
call	LCD_Char
;-------------0x02---------------Third character
movlw	 0x0A
call	LCD_Char
movlw	  0x0A
call	LCD_Char
movlw	  0x0A
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x0E
call	LCD_Char
movlw	 0x0E
call	LCD_Char
movlw	 0x04
call	LCD_Char
;-------------0x03---------------Forth character
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
movlw	 0x10
call	LCD_Char
;-------------0x04---------------Fifth character
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
movlw	 0x18
call	LCD_Char
;-------------0x05---------------Sixth character
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
movlw	 0x1C
call	LCD_Char
;-------------0x06---------------Seventh character
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
movlw	 0x1E
call	LCD_Char
;-------------0x07---------------Eigth character
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
movlw	 0x1F
call	LCD_Char
	movlw	0x80		;move to 1st row, first column
	call	LCD_Cmd
			;Display characters.
movlw	 0x00			 ;First character
call	LCD_Char
movlw	 0x01			 ;Second character
call	LCD_Char
movlw	 0x02			 ;Third character
call	LCD_Char
movlw	 0x03			 ;Forth character
call	LCD_Char
movlw	 0x04			 ;Fifth character
call	LCD_Char
movlw	 0x05			 ;Sixth character
call	LCD_Char
movlw	 0x06			 ;Seventh character
call	LCD_Char
movlw	 0x07			 ;Eigth character
call	LCD_Char
Character generator; http://www.dinceraydin.com/lcd/charcalc.htm
Though it gives decimal values, not HEX.
What pins (data/control) do you have on the display unit? Is there a part number and/or data sheet of the display unit itself?
Cant quite get it to work -
I initiate the LCD and can send ASCI characters fine, I cannot get it to work with Characters I try to generate
For example I send a 'V' using
movlw 'V'
movwf temp_wr
call d_write
i send a command using LCDWriteNibble per below- how do I proceed?
CODE
#define LCD_D4 PORTD, 0 ; LCD data bits
#define LCD_D5 PORTD, 1
#define LCD_D6 PORTD, 2
#define LCD_D7 PORTD, 3
#define LCD_D4_DIR TRISD, 0 ; LCD data bits
#define LCD_D5_DIR TRISD, 1
#define LCD_D6_DIR TRISD, 2
#define LCD_D7_DIR TRISD, 3
;#define LCD_E PORTA, 1 ; LCD E clock
;#define LCD_RW PORTA, 2 ; LCD read/write line
;#define LCD_RS PORTA, 3 ; LCD register select line
;#define LCD_E_DIR TRISA, 1
;#define LCD_RW_DIR TRISA, 2
;#define LCD_RS_DIR TRISA, 3
#define LCD_E PORTD, 6 ; LCD E clock
#define LCD_RW PORTD, 5 ; LCD read/write line
#define LCD_RS PORTD, 4 ; LCD register select line
#define LCD_E_DIR TRISD, 6
#define LCD_RW_DIR TRISD, 5
#define LCD_RS_DIR TRISD, 4
#define LCD_INS 0
#define LCD_DATA 1
D_LCD_DATA UDATA 0x57
COUNTER res 1
delay res 1
temp_wr res 1
temp_rd res 1
pumpdel1 res 1
pumpdelh res 1
holdcnt res 1
timefast RES 1
ptemp_4l RES 1
GLOBAL temp_wr, pumpdel1, pumpdelh, holdcnt, timefast, ptemp_4l
PROG1 CODE
LCDLine_1
banksel temp_wr
movlw 0x80
movwf temp_wr
call i_write
return
GLOBAL LCDLine_1
LCDLine_2
banksel temp_wr
movlw 0xC0
movwf temp_wr
call i_write
return
GLOBAL LCDLine_2
d_write ;write data
call LCDBusy
bsf STATUS, C
call LCDWrite
banksel TXREG ;move data into TXREG
movwf TXREG
banksel TXSTA
btfss TXSTA,TRMT ;wait for data TX
goto $-1
banksel PORTA
return
GLOBAL d_write
i_write ;write instruction
call LCDBusy
bcf STATUS, C
call LCDWrite
return
GLOBAL i_write
rlcd macro MYREGISTER
IF MYREGISTER == 1
bsf STATUS, C
call LCDRead
ELSE
bcf STATUS, C
call LCDRead
ENDIF
endm
LCDInit
banksel TRISD
bcf TRISD,7
banksel PORTD
bsf PORTD,7
call Delay30ms
clrf PORTA
banksel TRISA ;configure control lines
bcf LCD_E_DIR
bcf LCD_RW_DIR
bcf LCD_RS_DIR
movlw b'00001110'
banksel ADCON1
movwf ADCON1
movlw 0xff ; Wait ~15ms @ 20 MHz
banksel COUNTER
movwf COUNTER
movlw 0xFF
banksel delay
movwf delay
call DelayXCycles
decfsz COUNTER, F
goto $-3
;0x02------------------
; movlw b'00110000' ;#1 Send control sequence
movlw b'00100000' ;#1 Send control sequence
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
movlw 0xff ;Wait ~4ms @ 20 MHz
movwf COUNTER
movlw 0xFF
movwf delay
call DelayXCycles
decfsz COUNTER, F
goto $-3
;28---2
; movlw b'00110000' ;#2 Send control sequence
movlw b'00100000' ;#2 Send control sequence
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
movlw 0xFF ;Wait ~100us @ 20 MHz
movwf delay
call DelayXCycles
;28--08
; movlw b'0011000' ;#3 Send control sequence
movlw b'10000000'
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
;test delay
movwf delay
call DelayXCycles
;0C--0
; movlw b'00100000' ;#4 set 4-bit
movlw b'00000000' ;#4 set 4-bit
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
;0x0C
movlw b'11000000' ;#4 set 4-bit
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
call Delay1ms
;0x01
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
;0x01
movlw b'00010000' ;#4 set 4-bit
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
;0x02
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
;0x02
movwf temp_wr
bcf STATUS,C
call LCDWriteNibble
; rcall LCDBusy ;Busy?
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
call LongDelay ;2ms
movlw 0x4E
movwf temp_wr
call LCDBusy
bsf STATUS, C
call LCDWrite
call Delay1ms
return
GLOBAL LCDInit
LCDWriteNibble
GLOBAL LCDWriteNibble
btfss STATUS, C ; Set the register select
bcf LCD_RS
btfsc STATUS, C
bsf LCD_RS
bcf LCD_RW ; Set write mode
banksel TRISD
bcf LCD_D4_DIR ; Set data bits to outputs
bcf LCD_D5_DIR
bcf LCD_D6_DIR
bcf LCD_D7_DIR
NOP ; Small delay
NOP
banksel PORTA
bsf LCD_E ; Setup to clock data
btfss temp_wr, 7 ; Set high nibble
bcf LCD_D7
btfsc temp_wr, 7
bsf LCD_D7
btfss temp_wr, 6
bcf LCD_D6
btfsc temp_wr, 6
bsf LCD_D6
btfss temp_wr, 5
bcf LCD_D5
btfsc temp_wr, 5
bsf LCD_D5
btfss temp_wr, 4
bcf LCD_D4
btfsc temp_wr, 4
bsf LCD_D4
NOP
NOP
bcf LCD_E ; Send the data
return
LCDWrite
; call LCDBusy
call LCDWriteNibble
BANKSEL temp_wr
swapf temp_wr, f
call LCDWriteNibble
banksel temp_wr
swapf temp_wr,f
return
GLOBAL LCDWrite
; _____ _____________________________________________________
; RS _____>--<_____________________________________________________
; ____________________________________________________
; RW _________/
; ____________________ ____________________
; E ____________/ \____/ \__
; _________________ __________ ___
; DB _________________>--------------<__________>--------------<___
LCDRead
banksel TRISD
bsf LCD_D4_DIR ; Set data bits to inputs
bsf LCD_D5_DIR
bsf LCD_D6_DIR
bsf LCD_D7_DIR
BANKSEL PORTA
bcf LCD_RS
btfsc STATUS, C
bsf LCD_RS
bsf LCD_RW ;Read = 1
NOP
NOP
NOP
NOP
NOP
NOP
btfss LCD_D7 ; Get high nibble
bcf temp_rd, 7
btfsc LCD_D7
bsf temp_rd, 7
btfss LCD_D6
bcf temp_rd, 6
btfsc LCD_D6
bsf temp_rd, 6
btfss LCD_D5
bcf temp_rd, 5
btfsc LCD_D5
bsf temp_rd, 5
btfss LCD_D4
bcf temp_rd, 4
btfsc LCD_D4
bsf temp_rd, 4
bcf LCD_E ; Finished reading the data
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
btfss LCD_D7 ; Get low nibble
bcf temp_rd, 3
btfsc LCD_D7
bsf temp_rd, 3
btfss LCD_D6
bcf temp_rd, 2
btfsc LCD_D6
bsf temp_rd, 2
btfss LCD_D5
bcf temp_rd, 1
btfsc LCD_D5
bsf temp_rd, 1
btfss LCD_D4
bcf temp_rd, 0
btfsc LCD_D4
bsf temp_rd, 0
FinRd
return
LCDBusy
call LongDelayLast
; call LongDelay
return
; Check BF
rlcd LCD_INS
btfsc temp_rd, 7
goto LCDBusy
return
GLOBAL LCDBusy
DelayXCycles
decfsz delay, F
goto DelayXCycles
return
Delay1ms ;Approxiamtely at 4Mhz
banksel delay
clrf delay
Delay_1
nop
banksel delay
decfsz delay
goto Delay_1
return
Delay30ms ;more than 30 at 4 Mhz
GLOBAL Delay30ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
return
GLOBAL Delay30ms
LongDelay:
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
call Delay1ms
return
LongDelayLast
call Delay1ms
call Delay1ms
call Delay1ms
return
I can't see any generated characters in your code... you need to send them to the screen's CGRam and store them in locations 0 - 63,
Then display them by printing 0 through 7... there are 8 bytes per character ( lower 5 bits ).
What characters are you generating?
Response
I tried to generate and write a custom character using the below code - but I could not get it to work-------
call LCD_Init
call LCDWriteNibble
movlw 0x0E
movwf temp_wr
call d_write
movlw 0x11
movwf temp_wr
call d_write
movlw 0x11
movwf temp_wr
call d_write
movlw 0x11
movwf temp_wr
call d_write
movlw 0x1F
movwf temp_wr
call d_write
movlw 0x1B
movwf temp_wr
call d_write
movlw 0x1B
movwf temp_wr
call d_write
movlw 0x1F
movwf temp_wr
call d_write
call LCDWriteNibble
call movwf temp_wr
call d_write
