It's a transistor that uses a insulated gate like a mosfet to turn it on. Instead of controlling it by current it does it with voltage. That is the simple answer from a simple point of view. I'm sure others will give you better more technical explanations though.Hey all, what is an IGBT in simple terms?
Why would this guy use them in his SSTC instead of mosfets such as irf260 or 460?It's a transistor that uses a insulated gate like a mosfet to turn it on. Instead of controlling it by current it does it with voltage. That is the simple answer from a simple point of view. I'm sure others will give you better more technical explanations though.
This may help - https://www.infineon.com/dgdl/Infin...N.pdf?fileId=5546d462533600a40153574048b73edc
Google said:Which is better IGBT or Mosfet?
When compared to the IGBT, a power MOSFET has the advantages of higher commutation speed and greater efficiency during operation at low voltages. ... The IGBT combines the simple gate-drive characteristics found in the MOSFET with the high-current and low-saturation-voltage capability of a bipolar transistor.3 Oct 2011
Im sorry, what?Can someone make a recommendation here? I'm not sure what to do. Even the local company I hired here in North Port isn't sure how to optimize our property's systems.
He explains all of that in the link.Why would this guy use them in his SSTC instead of mosfets such as irf260 or 460?
