analog PIC18f
wilsonlai3
HELO TO EVERYONE
here is my problem,
i`m having difficulty in knowing how it works
(input)IR signal -> into pic18f452 output -> L293D -> DC motor
i don know how to write the c PROGRAM
because both also analog in and output
thanks guys
3v0
Coop Build Coordinator
Forum Supporter
First you need to know C and understand the concepts behind IR communication and H-Bridges.
Then break in down into steps.
1. Program the PIC to read the IR
2. Program the PIC to control the motor using the H-Bridge.
Where do you need help ?
wilsonlai3
guys,here are the program draft that try to simulate but it cant work.
so i not sure how to program it
the concept is like this,infront of car there will be a IR sensor which detect distance infront of car,if distance is decrease the speed of motor will decrease also,and vise verse.
here are part of the program.
unsigned int temp_res;
void main() {
ADCON1 = 0x80; // Configure analog inputs and Vref
TRISA = 0xFF; // PORTA is input
TRISB = 0x3F; // Pins RB7, RB6 are outputs
TRISD = 0; // PORTD is output
T2CON = 0b00011110; //set up PWM
CCP1CON = 0b00001100;
CCP2CON = 0b00001100;
CCPR1L = CCPR2L = 0; //initial PWM is zero
do {
temp_res = Adc_Read(2); // Get results of AD conversion
PORTD = temp_res; // Send lower 8 bits to PORTD
PORTB = temp_res >> 2; // Send 2 most significant bits to RB7, RB6
} while(1);
3v0
Forum Supporter
It is much easier to read code if you post it using the # icon from the menu. It place the code between [CODE][/CODE] tags.
void main() {
You are making me guess at what compiler you are using.
I see a adc read but no call to set it up. It is very hard to debug a parts missing turkey ! :)
3v0
wilsonlai3
i`m using MIKROC
to compile it
so the problem is as what u stated
i don noe how to call it and cooperate with PWM output
3v0
Forum Supporter
I looked at the compiler manual as did you. My question is why are you using the supplied ADC functions and not the supplied PWM functions. My guess is that they would work well together.
The PWM functions are
Pwm_Init
Pwm_Change_Duty_Cycle
Pwm_Start
Pwm_Stop​
This is the way you can combine the two examples from the compiler manual. You still need to figure out what value to set the PWM duty to based on the ADC reading. I did not provide header files or fuse settings. These you should be able to figure out.
void main(void)
  // setup ADC
  // setput PWM
  TRISC=0x00;
  PORTC=0xFF;
  Pwm_Init(???);
  Pwm_Start();
  while(1)
      // code to read ADC
      // code to set PWM duty cycle
      Pwm_Change_Duty(???);
I do not use this compiler but it looks lke this should work.
mhafiz258
programing
could u please write a little bit programing to program the pic to control the dc motor..
EE World Online Articles
Loading
