analog 2 digital converter...
TKS
hi all.
i'm now reading in some voltages..
but the thing i find is that the maximum value i find = 1019/1020
and not the 1023..
i have put 2 resistors in series and the in the middle of them i puted a wire to the pic..
and the last res is a resistor you can adjust..whit a button...
it also can draw to 0 ohm...
i don't untherstand wy i read 1020 in stead of 1023 any one suggestions..
TKS
my vref = 5,07 volt says my multimeter..
1. Make sure you have the ADC conversion clock divider set correctly for your clock freq.
2. Make sure you have waited the minimum time after the ADC has been enabled and you have selected the desired channel before setting the GO bit.
VDD
even when i put it strait to VDD it says that...
i compare also to VDD
so it should says 1023 then...
TKS
