I am having an issue with my stock crank angle sensor giving me a 8v pk to pk voltage where the spec is 14v pk to pk. The vehicle will not rev past 6800.
I built two circuits with op amps trying to amplify this signal and got two different outputs which I am unsure of and was hoping someone could shed some light.
this is the circuit:
I used two 9v batterys to create the positive and negative vcc's
I built one using a tlo82 BiFET op amp and when I t'd into the signal wire (just to check the output) I was able to amplify the signal by about 1 volt. However when i cut the wire and actually put the amp into the loop it shows 14v pk to pk at the input and output. (i dont understand why this is changing the input?)
With this circuit in place it wont rev to anything past idle so im assuming is out of phase and throwing the timing off??? Because the signal is the same before and after the op amp I really have nothing to compare it to for the phase.
So i tried again with a standard 741 op amp and the output was changed to a 2v pk to pk square wave. When cut into the loop this was able to rev to 5k but then expirenced break up in the ignition. Im guessing the slew rate wasent fast enough or maybe im going out of phase again...
Any advice or insight would be much appreciated.
Thanks, Mike
Thanks, Mike
